Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Here is a link to the Bosch Website. You will need some model info and follow the link to a service/user manual to help you solve you "No Start" condition. Instruction Manuals
Look up the senior officers of Bosch and contact them directly regarding your question. (I believe the corporate offices are in Europe--contacting the US offices yielded nothing.) A few years ago I did this when experiencing Bosch dishwasher issues not being repaired while covered under warranty. After contacting the CEO, we got a new replacement.
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
simply go back to the shop it was bought in and they have to supply with the instructions in english at your request at no further charge,email bosh at there customer services they will gladly supply you free of charg.adrian
