SOURCE: GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
terminal.
See these files for help:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My GE microwave now comes on when I open the door
One of your door switches is sticking or misaligned. Eric
SOURCE: Microwave does not turn off when door is opened
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
One test that sometimes
helps is to
gently lift up (and/or push down) on the door or handle as you try to
start it. If it works or tries to work, then it's a door switch mount
or
door alignment issue.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so with a one-year
guarantee.
We're
happy to help you with free advice and we'd appreciate your thoughtful
William E. Miller
[email protected]
SOURCE: The microwave turns on when the door handle is
Hello :
If there is any resetting button , then press it to reset your Microwave oven . If that didn't solve the problem , then I recommend you to replace it if that's possible or just take it to the service since you still have to guarantee .
good luck .
rate please !
SOURCE: I have a GE Spacemaker XL1800 over stove does not cook
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Even though a door
Door switch
the
There are
The screws on these
activated properly.
Sometimes it's
helps is to
or
If you or someone you
know decide to look
into it, we have critical information on safety, disassembly and door
switches at our site.
number here.
There
behind the
components.
At
If you only need a
We're
