SOURCE: how to remove motor from
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
SOURCE: I have a bosch front
after checking the fose could be a break in the cable or remove the pcu and check relay you may need specialist help
SOURCE: Did'nt find what I was looking for. I need a user
When going through my paperwork I found the manual I was looking for in english. Many thanks for your help. T. Maddocks.
SOURCE: Washing machine heater not working
Only way to be sure if it is the heater, is to test it with a meter.
They are a fairly straightforward job to replace
Please rate my solution.
Thanks..
SOURCE: My Bosch WFO 2062 is leaking water while it works.
mine was doing the same and i got the door seal/gasket changed
