I believe that error code indicates that you've got a leakage error, which means water has leaked down into the base of the dishwasher. You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water, but then you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
SOURCE: How do I reset DMt400RHS dishwasher?
read you instruction manual, section troubleshooting, go to the menu, and proceed. If you do not have instr.manual download from www. retrevo.com or www.fitness.manualsonline.com
However you can reset from the main power, reset the c.breaker that control the dishwasher machine.
God bless you
