Hi Bill Currier, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What device?Hi Bill Currier, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What device?
You can't post conmments that contain an email address.
Sometimes pairing is hard but your phone especially Bluetooth device to your phone cell phone to not recognize your Bluetooth device may not pay very well with some phones I recommend a universal Bluetooth earpiece has high capacity to go with any model carry your phone1 only get you one or two
First thing you need to do is to go into your Bluetooth settings and make sure that your phone is set up to pair with a device. Next, make sure that the device your are pairing to your iPhone, is in pairing mode. After both of these steps are complete, the phone should recognize the device and you can complete the pairing process. Hope this helps!
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following. 1. check that BT is off on both devices 2. turn BT on on your mobile phone 3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect. Dont try to power on the headset before turning BT on on your mobile phone. If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again. Don forget, that the headsets also have to be charged..
According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in.The phone should reset itself to pair the bluetooth headset with the phone. If that does't workremove the device from the phone and start from step 1. I removed the device from the phonethen I took the battery out for 30 seconds. Then I paired the bluetooth and followed the nextsteps to complete the sync.
Headsets don't be synchronised, as syncing means to update to devices with each other.
Bluetooth headsets are paired. Pairing means that both Bluetooth devices recognize each other and trust each other, so you do not need to provide any type of confirmation.
So, follow the phone's manual to see how to switch on the Bluetooth and make it visible. Now, there must be an option like make a new paired device. Consult your manual for this. The phone will search for a deivce and they will be paired.
You can even pair a PC and phone, phone and phone and every kind of Bluetooth enabled devices.
To put the Drivespeech into pairing mode - with power OFF, press the power on button until the Drivespeech powers on and CONTINUE to hold the button until it announces it is in pairing mode and the LED flashes alternate Red/Blue.
Select 'Discover' on your phones Bluetooth menu and enter the code when requested (usually 0000 or 1234)
HTH
