SOURCE: NEC Dterm 80
Press feature; press 9; press #; use key pad to change time; press recall to change am/pm; press feature again to when time correct; new time should show.
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
SOURCE: NEC Dterm80 Name change
OK, I got this from somewhere else. But anyways, pick up the phone and dial 700, then dial the extension number, then finally you can punch in the name like you would doing a text message. When you're done, hit Hold, hang up, and hit Speaker twice.
SOURCE: Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
SOURCE: Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
