SOURCE: Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
SOURCE: HELP! power outage problem
Your burglar alarm panel, shorts the phone line when it sounds off, while it is auto dialing out. So that is why no phone.
My strong recommendations is to use a UPS on all of the items that are on the phone line. Problem should be solved.
You don need big ones either. Small ones will do just fine. I have them too.
www.storminproteciton.com
SOURCE: PHONE CUTS TO MESSAGE AFTER 2ND RING. I WANT IT
if answering machine is on phone , go to messaging menu it should have a setting for number of rings... make sure toll saver option is off!
Question: What does this have to do with a Panasonic KX-T7425 phone? Is a Panasonic phone hooked up to your Partner system?
Sounds like the system believes the phone is in use. Is the partner phone in question an MLS model? MLS-6, MLS-12 etc.. They all have keypad problems and buttons could be activating on their own randomly, making the phone in-use on the system. The message waiting light may not come on until the phone is no longer in-use. Usually phones with this problem will at least beep randomly when it thinks the buttons are being pushed.
