Setting the 12/24 time format The 12 hour format is set as the default. To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format. Close the CONTROL COMPARTMENT COVER.
I have the Yoho Sport Fitness Tracker Smart Watch. There was no option to change time format on the Yoho Sport app. However, on the watch, long-pressing the power button while on the time screen changed the time format between 12 and 24 hours.
In your computer, go to "Windows Help and Support".or go to step 4.
Search for "clock time format"
Select "Change the display of dates, times, currency or measurements"
Click to open "Region and Language"
Select "Additional Settings"
Select the TAB named "Time"
Where short time and long time are formatted change short time to: h:mm tt and the long time to h:mm:ss tt (note: the h is lower case for 12hr and uppercase for 24)
Click apply after you change the time format and close open windows.
You just need to set the correct time zone from Control Panel.
For XP: Just double click the time from your system tray, click on Timezone tab then choose your timezone from the drop down menu then click OK.
For Vista/7: Click on the time from system tray, click on "Change date and time settings". A window will pop up, click on "Change time zone" button, choose your timezone then click OK.
To change your Armitron WR165 watch from military time (also known as 24-hour time) to 12-hour time, you will need to follow these steps:
Press and hold the "mode" button until the display shows the current time format (either 12H or 24H).
Press the "set" button to toggle between the two time formats.
When the desired time format is displayed, press the "mode" button to exit the setting mode and save the new time format.
If you are having trouble changing the time format on your watch, you may want to consult the user manual for your specific model, as the steps may vary slightly depending on the version of the watch you have. You can also try contacting Armitron customer support for further assistance.
START->CONTROL PANEL->DATE,TIME,LANGUAGE.....->Change format
of numbers,dates and time. Under regional and language option click
customize option and select time tab under customize regional options . There would be an option to change date, time change format. Click that and it would fix the issue.
