Question about Husqvarna McCulloch Garden Tiller, 5hp Honda Engine, Forward & Reverse On Rotors, Complete With 2 Pairs of Rotors
Why won't my rotor tiller stay running after starting Its a briggs and stratton
    Problem Solver:
  • 7 Answers
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Posted on Jul 15, 2014
2 Suggested Answers
6ya staff
SOURCE:
Dwain Pippen
  • 376 Answers
SOURCE: engine runs backwards?
Starter clutch needs to be cleaned or replaced. What is the model # and type # on the engine
Posted on May 17, 2009
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
What size belt for lazy boy tiller
www.hyperparts.com/ope/LazyBoy-oem-list.htm
Jul 05, 2014 | Garden
5hp Briggs engine on craftsman snow blower won't stay running
Remove the nut that holds the float bowl on and clean the hole on the side and the hole that goes down the center of the bolt.
Jan 05, 2014 | Briggs & Stratton Snowblower Snow Blower...
Briggs and Stratton intek 900 Series 205cc It will starts but it wont stay running.
The usual cause for the problem you describe is related to fuel/
carburetion. Today's formulation of gasolines have a shelf life of only 4-6 months before they start gumming carburetor. Other forms of fuel contamination (dirt, water, etc) may also be the culprit. First step is to remove and thoroughly clean both the tank and carburetor. Reinstall. Install a small engine filter in the gas line when you reassemble. Use FRESH gasoline after you are ready to start your engine.
Oct 14, 2013 | Briggs AND Stratton Intek Briggs &...
22 hp b/s won't stay running
check spark make sure its bright blue but sounds like a dirty carb needle valve isnt opening enough not letting enough fuel in
Jun 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Where do I get a rebuild carburetor kit of a 1973 Briggs and Stratton rotor tiller?
with the model and spec numbers from the front cover any power equipment shop should have the parts
Jun 05, 2012 | Briggs & Stratton Garden
Husqvarna McCulloch Garden Tiller, 5hp Honda Engine, Forward & Reverse On Rotors, Complete With 2 Pairs of Rotors Logo
348 people viewed this question
Top Husqvarna Garden Experts
Marvin
Marvin
dannydoesita
Wayne McNeil
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
