HP LaserJet 1020 Printer Logo
A
Anonymous Posted on Jul 08, 2014
What does error 3 on canon mg3150 mean, flashing orange lights by c & b?
1 Related Answer
Anonymous
  • 2120 Answers
  • Posted on Feb 06, 2009
SOURCE: orange light is flashing
Unplug the power cord for 10 seconds
I have changed my ink in my printer but it will not work getting code 6 what does this mean I have a canon mg3150 pixma
Take a look here https://printerthinker.com/canon-pixma-mg3150/
It includes all error codes for this model
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
2helpful
Disable cartridge monitor Canon MG3150
try tthis
Press and hold the Stop/Reset button until the error clears.
If your printer doesn't have a Stop/Resume button, use the Cancel button. Hold the button - until the Alarm LED stops flashing,
or until the error message disappears. This takes 6-7 seconds.
Note: You will have to repeat the whole process with every cartridge that indicates empty (in the ink monitor).
Good Luck
Thanks
I have canon pixma iP100. green & orange light is flashing it won't print comes up error 6000.manual says to take battery off turn off power for at least 5 mins then turn on tried this still s
Turning off and on pressing buttons does not work. Error 6000 means either paper is in the way. Try rolling the paper bar inside the printer to remove paper jam. Or, most likely the ink well, right hand side, needs cleaning .use toilet paper to remove excess ink in the ink well. Just recovered my printer doing this .
2answers
2answers
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
6helpful
2answers
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
k24674
Grand Canyon Tech
Grand Canyon Tech
