SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
SOURCE: dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
SOURCE: **My dishwasher normal light keeps blinking**
I have the same problem. I have tried turning off the breaker and the door seems to be locking, but still won't work. Any other suggestions?
SOURCE: blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
SOURCE: Whirlpool dishwasher gu2500xtpq1. Clean light
The
blinking clean light is an interruption in the dishwasher program that
usually indicates a component problem or program malfunction. If a
component is defective, it's usually attributed to the heating cycle or
thermostat failure. To rule out component failure, or program error,
the following link explains how you may be able to clear the blinking
clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep
in mind all dishwashers are not alike and have different panel options.
If you do not have the same set up that I have mentioned, the tech
sheet for your dishwasher will explain the touch pad functions. The
tech sheet is located behind the lower toe panel under the door and
lists the proper sequence of buttons to push for diagnostics and
troubleshooting. Just remove the screws that hold the panel in place
and remove.
NOTE: Sometimes the tech sheet is located behind
the inner door panel. You will need to remove the screws securing the
inner panel to access it if this is the case. Make sure you turn off
the main power breaker before doing so.
In many cases, I found
this to be a momentary glitch in operation. If the problem keeps
reoccuring the number of flashes is an indication of WHICH circuit is
causing your problem. As all dishwashers differ in operation and
features, refer to your tech sheet for the recommended troubleshooting
steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry
combination, some use the Sani-Rinse/Heated Dry combination. Some use a
sequence of three, others use a sequence of 5 pushes of the buttons. If
the tech sheet is not located behind the lower toe panel, it should be
affixed somewhere under the dishwasher. I have also found them located
inside the inner door panel. Please post back and let me know if you
still need assistance.
