IGNITOR
To get to the ignitor, you must remove the front panel. To do this, first open the door and remove the two screws and plastic tabs that are directly across from the door hinges (left side if rt hand swing door and right side if left hand swing door). Next, support the door and remove the two screws from the hinges and remove the door. The front panel is now loose and will pivot down from the top out. Pull it out a couple inches then straight up and out of the way. You now have access to most all of the components internal of your dryer, including the ignitor. I know it's late, but didn't see an answer for it yet....and I have mine apart right now for the same problem (runs with no heat).
