umm if I understand correctly you want one document printed same document on both sides select double side printing the where it ask for how many copies you want send to or how many of the documents you want in increments of two ex. 2=1 double side copy,4=2 double sided ,6=3double sided
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Does your machine have double siding capabilities?
If so on the control panel under original / copy. select 1:2, this will give you a double sided copy from a pair of single originals even off the glass.
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
I don't think the HP Officejet 5780 have the capacity automatic for double side copy.
nothing in the printer specification have the double side copy listed.
what you can do is copy one side and trun the paper over and copy the other side.
