It is funny that the Model Number has 1990 (1A81990STDM) in it. The serial number is the last part '755117'. My guess is that it was designed and first released in 1990, updated perhaps, but this one was made in 2015.
Edited text with a wild guess at the maker. Make model (what it is) in all questions please.
Category moved to John Deere Tractor.
If it was working before, there is no need to worry about the firing order as that never changes. Things to look at;
Clean and correctly gapped spark plugs,
Clean gas,
Fuel filter?
and a clean carburetor, float bowl and jets.
John Deere 3020 Engine
Engine Detail
John Deere
Firing order:
Starter volts:
Oil capacity:
9 qts 8.5 L
13 more rows
Jul. 10, 2020
This John Deere model 3020 Gas and Diesel Tractor Service Manual is a digitally enhanced reproduction of the original manufacturer-issued Shop Manual.
US$120.98 · ‎In stock
This is a new reprint of John Deere Service Manual SM2041 for the John Deere 3000 Series Tractors shown above. It is dated June 1961. Includes 3010 & 3020.
you will need to look for second hand areas -ebay ,local classified -web searches- JD parts for those series are very hard to find but their out there look on ebay under john deere 1020 tractor and also tractor boneyards like marshall machinery in pa or steiner parts -if the exhaust is cracked look for a machine shop they may be able to do repair until replacement is available
your number 4045tf258 should be a industrial generator that number is the model number John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
JD 400 Garden tractors were made from 1975 - 1983.
Serial Numbers
1975: 30001
1976: 55001
1977: 70001
1978: 80001
1979: 95001
1980: 120001
1981: 155001
1982: 190001
Go to this site and you may be able to track it down. John Deere 400 attachments
http://www.tractordata.com/lawn-tractors/000/0/4/41-john-deere-400-attachments.html
Be sure to read this discussion on serial numbers.
"Find the REAL serial number
There are usually a lot of different numbers on a tractor. The engine, front axle, and cab may all have their own serial numbers. Various components may have parts or casting numbers. Make sure you have actually found the tractor serial number, and not one of these other numbers."
You will have to first know what kind of transmission you have. You will have to consider if it is manual or hydrostatic drive. The transmission model number should be stamped usually on the top of the transmission. Yes transmissions are interchangeable, for example some John Deere, Craftsmans and Husqvarna all use the same transmission. Peerless is a manufacturer of these, the only one I know of. So don't let anyone tell you that you can ONLY use a John Deere product. To determine what transmission you can cross over with, get the model and serial number off of your John Deere's transmission. Call a small engine repair shop and ask them what all transmissions it will cross over with. Let them know you are aware that Peerless manufactures the same transmissions for most all riding mowers and that they will interchange. If they are uncoperative, contact me with the model and serial numbers off of your transmission and I will cross reference it for you. But try to get model and serial numbers for other brands from them, then check these against used ones. You will need to tell them if it is a hydrostatic transmission or manual and if so what speed manual.
