Motorola RDV2080d Two Way Radio Logo
E
Eric Mason Posted on Jul 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn it on, it says FAIL 008
It makes a high pitch sound, then says FAIL 008 on the display. It stays on the screen and you can not use the radio.
Jim Jordan
Level 3:
Master:
  • Master 442 Answers
  • Posted on Jul 16, 2014
Jim Jordan
Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114917
Points
1360
Have you tried resetting to factory defaults? Here's how:
Radio101 How To Reset Motorola RDX Series Radio
1 Related Answer
eradiostore
eradiostore
  • 1672 Answers
  • Posted on Oct 21, 2009
SOURCE: Fail 008 on the display
You can reset to the factory default settings to try and clear the problem. If you do this, you will need to reprogram your radio to match your other units OR reset ALL the radios you have. If your radios were never programmed by yourself or the dealer, you may have been on the factory settings anyway, so you wouldn't have to worry about programming. You'll know right away because your radio will either talk to the others or not.
To reset: Press the PTT, SB2 and SB1 simultaneously while turning ON the radio until you hear a high tone chirp.
My Freemotion 11.9 Treadmill has a high pitched noise coming from the electronic board. What could the issue be?
Question edited for clarity and fix the model number, no 'o'.
Question moved from Televisions Category to maker Category.
Try and find a repairer for the board, this make does not have a maker website, so made in China. I can't think of anything on a PCB that would make a noise.
https://www.google.com/search?q=freemotion+11.9+parts
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
1helpful
I have a Sony Wega KDF-E50A10 TV, and when I turn it on, the screen stays black and it makes a high pitched sound. Please help.
that high pitch sound is comming from the HV capacitor in the power supply.only a tech can remedy that problem.kindly take it to a tech for repairs.
When turning on samsung hln467w, lamp light blinks, screen stays dark, can hear audio from tv show, but then a high pitched sound begins for a few seconds. The tv turns on and off for a few cycles with the...
The tv have a colors wheel,have a whinning high pitch sound,mean colors wheel is warping not spinning right any more.The colors wheel is dead,must be replaced.The tv have high pitch sound,shutdown the projection lamp.The projection lamp might be dead or not?Not yet determine dead or just shutdown by the nonfunction of the colors wheel.
1helpful
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
