SOURCE: coil gap
Remove the plug. Place a business or index card between the coil and flywheel. Rotate the flywheel until the magnet holds the coil tightly against the card, tighten all fasteners. Rotate the flywheel until the magnetic attraction eases and remove the card. Rotate the flywheel through a couple of revolutions and ensure nothing drags or contacts the flywheel. HTH
Lou
SOURCE: air gap setting
I assume you are speaking of the ignition module pole gap to the flywheel. Rotate the flywheel magnets under the ignition module poles, and use a thin business card for a gauge. With the card in place, loosen the module screws and allow it to contact the magnets, then re-tighten the screws. Rotate the flywheel to remove the card, then turn the flywheel one full turn to make sure the gap does not close up at any point. Don't forget the ignition switch wire. Hope this helps!
