If the dryer is getting hot (the heater element is working) but the clothes aren't drying, it suggests that there is insufficient air flow through the dryer. Remove the exhaust tube from the back of the dryer. With the tube removed and the dryer running, check for hot air (lots of it) flowing out the exhaust vent of the dryer. If there is good air flow, check the exhaust tube for lint build-up or a clog that is blocking the air from flowing through the tube. If there is no air coming out of the exhaust vent with the exhaust tube removed and the dryer running, it suggests that the problem is with the exhaust fan inside the dryer.
SOURCE: Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner. This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing. The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs. The top thermostat, mounted above the element is the operating thermostat. It probably is one of the two thermostats. Its a very good idea to replace not only both of the thermostats, but the fuse as well. The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas. The high limit thermostat (Maytag Part# 53-0771) is an easy replacement. Something is causing the unit to short cycle. Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on). By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on. This is really not recommended, if the high limit is out, it will not be good. Just easier to replace them both.
SOURCE: my dryer isn't drying my clothes!
soundsmore like a coil kit thats gone bad,located atop the gas valve assy istelf, part number 279834 retails for about $20
SOURCE: My Crosley dryer not drying
Try resetting the dryer pair of breakers in the house electrical panel--push off, then on. Try the dryer again. If still nothing, using a voltmeter, read the voltage at the two slanted slots in the power socket--you should see ~ 230 volts AC. If zero or near it, one of the breakers is defective or a wire is loose on either end. If you read voltage, then the problem is inside the dryer or the power cord.
SOURCE: MY CROSLEY DRYER DOES NOT GET HOT AND DRY MY
most likely the element. to lift the top - slide a putty knife between the top and front , push the two clips toward the back and lift the top. the element is at the right rear. check for continuity with an ohm meter
SOURCE: Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.go ahead and pop the top(after unplugging the machine) Get the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
