On the reviews this machine is supposed to have this stitch. I downloaded the manual but it is not in there. That is the main reason that I bought this machine. Can you help with that. Thank you
SOURCE: mine is a simplicity 804 easy lock
Your knives may be blunt and need sharpening or replacement.
Check also if the knives are aligned properly. Remove the material and turn the handwheel slowly. The knives should pass each over like a pair of scissors and there should not be any cap between the blades.
If everything seems to be okay and it still does noet cut tne material, replacement is the only option.
SOURCE: Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
SOURCE: Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
SOURCE: manual easy lock 804
Copy this entire link: http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
