Question about DeLonghi DE500P Dehumidifier
Steps to turn on which mode has to be for just take water out
Steps to turn on the dehumidifier 500 which mode has to be to take the water out
I have a fdl70s1 and will only work in continuous mode.. Collects water fine but turns off when I adjust humidity setting
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
Oct 15, 2014 | Frigidaire 70-Pint Dehumidifier -...
Good Afteroon Friend, this is Z. Thank you for your inquiry!
Typically there are one or two reasons why your dehumidifier is not collecting water. Either the setting might be set too high or not enough moisture in the room. I suggest changing the set point to a lower setting. Ashumiditydrops in the room the amount of water will decrease and very little water may be generated even when in continuous mode. If these basictroubleshootingtips prove ineffective, then your dehumidifier may possibly have system issues. Is your dehumidifier still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy in that regard. Best!
Sep 05, 2014 | Frigidaire Dehumidifiers
DE 500 P. Unit is almost new but not used for many years. water is leaking under the unit around the tubing.
Did you solve this problem? Mine is only 2 years old and is having the same problem.
Sep 06, 2011 | DeLonghi DE500P Dehumidifier
Hello, I have a Danby DDR586R dehumidifier. Please help me troubleshoot the problem that it is not working. I turn it on and have selected different modes but there is no water going into it. Thank...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 08, 2011 | Danby DDR586R Dehumidifier
Our Haier dehumidifier keeps getting into this start/stop mode where it just starts to begin a cycle, but then it turns off right away, without really getting going. Sometimes it does this every few...
heatman101
Apr 12, 2011 | Haier Dehumidifiers
I am only getting about 1 qt of water every 24 hrs. and it is in a very humid area. the compressor is running along with the fan. the coil is iceing over. the unit goes into defrost mode yet water is...
heatman101
Jan 22, 2011 | Haier HDN455 Dehumidifier
My whirlpool dehumidifier runs but doesn't get cold or condense moisture what are the steps used to find the problem
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Oct 27, 2010 | Whirlpool AD50J Dehumidifier
Amana 30 (looks like dk25) unit runs but coils freeze up
Most dehumidifiers have a defrost mode in which the compressor is turned off to give time for the frozen water to melt. The freezing problem ocurrs when the unit is used in very cold weather. Check your manual to see if this unit comes with automatic defrost mode. If it does, it would appear that it is not operating correctly and you can request warranty service. If no defrost mode is available, then your only option is to heat up the room in order to use the dehumidifer within its limit of operation. Some units can operate as low as 36 F, but most units cannot go that low. Find out what your unit's specs are from the manufacturers web site.
Jan 04, 2009 | Amana D530M Dehumidifier
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
DeLonghi DE500P Dehumidifier Logo
149 people viewed this question
Top DeLonghi Dehumidifiers Experts
nm156
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
