6 DISC CD Changer in trunk worked yesterday on 2002 mercedes clk430...says no cd changer
If your 6-disc CD changer in the trunk of your 2002 Mercedes CLK430 was working fine yesterday, but is now displaying a "No CD Changer" message, there may be a few things you can try to troubleshoot the issue:
1. Check the connections: Make sure the CD changer is properly connected to the car's audio system. Check the connections for any loose or disconnected cables. Also, check the fuse for the CD changer in the car's fuse box.
2. Check for jammed CDs: It is possible that one of the CDs in the changer is jammed, which can cause the error message to appear. Try pressing the eject button to see if any CDs are stuck in the changer. If so, try gently removing them.
3. Check the CD format: Make sure the CDs you are trying to play are in a format that is compatible with the CD changer. The CD changer may not be able to play CDs that are scratched or in a non-standard format.
4. Try resetting the audio system: Try resetting the audio system by disconnecting the car battery for a few minutes. This may reset the CD changer and fix any software issues.
If none of these solutions work, there may be a hardware issue with the CD changer. It may need to be repaired or replaced. You can consult a mechanic or audio specialist for further assistance.
