Scanner seems to work fine but there is times that I loose all data even when the battery is fully charge?
Portal motorolasolutions com for Motorola Solutions Support
SOURCE: Scanner isn't scanning all the time
It doesn't sound like a power issue. Most likely it either needs cleaned, or it needs the laser recalibrated or replaced. Try cleaning the glass for starters, and then hold the scanner about two inches from a white piece of paper. You should get a solid, bright red line. If the line is distorted you need to recalibrate the laser. If it's dim, the laser unit is going out. The laser can be replaced, but I don't know if it's one of those things where the part plus labor costs more than replacing the scanner.
SOURCE: NOT SCANNING CORRECTLY
I'm guessing you are using the USB version and the power that comes from the comuter via the USB cable.
It is quite likely that the problem you are having is due to power sag. .500ma is the limit from P.C. s
Do you have a 15 foot cord on there? If so try a 6 foot cord. Sagging still occurs with a 6 foot cable ...but only half as much. If the problem goes away you are on the right track.
I have a cable (I should say Motorola has a cable) with a separate power supply that should fix the problem.
SOURCE: no data is transmitted
you need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
SOURCE: MC 9060 not retaining programming
We have the same problem, and according to our supplier we had to use the Regsave for saving the settings, due to internal proceudres, we haven't use the devices for a year, but now we have to use them again....
We have found this solution in the net, perhaps will help you...., now we are trying to find out the RegSave utility, if you find it, PLEASE e-mail me at [email protected] THKS
quote
Some brief notes about the use of RegSave on Symbol 90X0 terminals, specifically the 9060 with the 802.11b RF option.
You will need RegSave_2_53_04.zip
Unzip this and locate the file RegSaveCED.exe in the 9050 folder.
Connect your terminal as a guest in ActiveSync and explore it using Win Explorer. Locate the c:\applications folder and copy the RegSaveCED.exe file to this folder on the HHT.
Now you can uncouple the HHT and click start menu and Windows Explorer to look at HHT's local files. locate applications folder and locate the RegSaveCED.exe file... double tap
Now screen RegSave EMEA TS appears.
In Registry section press "Create Template File"
Accept \Application\RegSave.tpl option offered
Click Create template and wait forever !
............. time passes ..................
The app rattles through all the registry entries and builds a file with them all in. Just when you assume it'll last forever it stops...
Now back to the main screen ...
Click OK (top right) to exit the app
--- oOo ---
Now set your IP parameters and RF bits... in fact anything you need.
--- oOo ---
Now re-load the RegSave app.
Press the button in the Registry section entitled "Save Current Configuration"
I got some missing file error here which I rode over roughshod... basically it's looking for a registry exception file. You can create this but and it can be a list of ignored keys but for our purposes it doesn't matter so I just said "Yes"
It'll do some stuff regarding comparing and checking for differences, then it saves the changed bits.
Now you can exit RegSave and try rebooting... it should have saved the changes to the Registry and everything should be the same as before
unquote
SOURCE: The battery seems to not be charging, it only
Check the battery leads to see if one of them was severed somehow. If the leads look good. If the leads look good replace the battery.
