My Whirlpool DU943PWKBO quiet partner II starts and then stops during a cycle and does not drain. It will run for 10 seconds or so and then stop for several minutes and then repeat. It leaves water in the dishwasher, when I push the cancel/drain button it will drain out just fine. What should I check?
SOURCE: quiet partner II is stuck in cancel/drain mode...
you need a new cycle selector ...or "timer "....
SOURCE: Whirlpool Quiet Partner III Will not drain at the
It sounds like the control unit has gone bad and you will have to replace it...the replacement is not very hard, just make sure to mark the wires so you get them back were they belong on the new unit.
How to Buy Appliance Parts Online
heatman101
SOURCE: why did my quiet partner II whirlpool dishwash just stop mid cycle?
see this possible causes:
Water-heating cycle
heat, wash, and rinse has the 3 cicle, principal problem is the heat cycle, when the water reach the level ( by heating water elements) test the heating elements , most ot the time fixing this .the problem is o.k
Timer
sincerely. God bless you
What I have come to realize is that the position of the top shelf prevents the soap dispenser for opening. I have tested this multiple times and the same problem happens. I will be cutting off the bars on the left side of the top tray tomorrow to validate. No problems with the motherboard. All the problems are with the soap dispenser not opening. That is when the unit stops and enters cancel cycle. Bad designing with the soap dispenser opening from the top
