SOURCE: Vista unable to install Futura software
I found a solution that seemed to work for my setup (Vista-Futura 200): Go to the Futura support site www.futura-support.com . Choose "Service Updates" from the left-hand Menu. Choose "Quantum® FUTURA™ (CE-200) Owners running Windows XP Service Pack 2 operating system WITH one or more of the Options (AutoPunch, CrossStitch, PhotoStitch, and HyperFont) installed". Look for the bullet-point list in the explanations. It says there: "If you own the AutoPunch Option and you could not successfully install it, download the Service Update by clicking here." Select the highlighted link, download the patch and install it. Worked fine for me, I hope it helps you, too.
I found the patch here:
http://www.futura-support.com/downloads/patch.htm
Hope this helps!
SOURCE: Problem with birdnesting
The bobbin you want to use is slightly shorter (Not Much ) and has a polished almost rounded edge ,,,15 class bobbins tend to float at speed and jam up
SOURCE: singer futura ce200 software problem
You may ask your Singer supplier about Futura 2.5, this version of the software supports old machine models ce100/200, contains more features like the software for newer machine models and works under new OS including Windows 7.
SOURCE: Singer CE-200 Quantum Futura
i need the 2.5 upgrade software for my futura ce200 because i have windows 7 can i download it off the net??
