SOURCE: Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
SOURCE: Need a new Clean and Charge Base
yes, you can find it online , also you can find it on ebay if you search for braun 8585 .
