The phone has been blocked so is there away I can change the imei number
No sorry, IEMI numbers cannot be changed however depending on the carrier that blocked the device, you may be able to give them a call to get it unblocked. Sometimes even for free.
U can't change imei number. But maybe u can go to service center to unblock your phone.
SOURCE: imei blocked
You need to call your phone company, they have control of unblocking the IMEI code. Sorry your having so much trouble with this, hope i've helped you!
SOURCE: the phone is blocked and imei is blocking some
The unique IMEI code allocated to your phone has been blocked because your phone has most likely been reported as stolen or using a fake/illegal IMEI.
If it is not the case, and if you are the original owner and you are using the original IMEI as indicated on your device identification label, contact your Mobile service provider and ask them how to remove this IMEI number from the worldwide shared IMEI blocked list.
Hope it helps: let me know how you go.
