Hello Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing it appears that your Frigidaire cooktop may possibly have a faulty switch or EOC (electronic oven control). This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of. The switch for that burner has shorted and will need to be replaced. It will be fine once it is repaired.
SOURCE: Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
SOURCE: Dacor SGG365 one burner control won't cause spark
your problem is most likely the spark switch, but it could be you spark module but that is highly unlikely
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Whirlpool Flat cooktop burner not heating up
Try cleaning the knobs. I did the same thing you did (turning the circuit breaker off but that did not solve the problem.
My wife just tried turning the knobs and that seemed to work. It appears that one of the knobs may have been so sticky that the though it's in the OFF position it thinks it's still ON.
SOURCE: Front burner won't ignite when turned on.
Hello there:
if you Heard or seen this poping you probably have shorted out the ignitor mechanism You can try unplugginh the stove and removing the part and inspecting it and see if it can be cleaned and doubkle check the wiring to see ithatthey are not greasy or there is any buiold up on the wires then reinsert the part and see if it will work now but if not you will have to replave the ignitor ok
If you have a local appliance repair center you should be able to get the part from there if not go online and go to www.repair clinic.com youcan order it from them ok
Hope this is very helpful for you
Best regards MIchael
Testimonial: "Thank you so much for your help.I am definitely going to take your advice. Working on it right now. Much appreciated."
Thank you for your inquiry, friend!
From the information you have provided your Frigidaire range is not allowing steam to come out. If your vent is blocked it will not release the hot air or steam. Could you provide me with your model number? You can locate the serial tag (which lists your model number) on the door frame of the lower drawer. With the model number I can provide you further assistance. -Matt
I appreciate your post, friend!
I noticed your question is labeled under Frigidaire cooktop model, FEC30S7E. I have located the Use and Care Guide for your cooktop and I was unable to locate a lock feature. You could perform a reset on your appliance and you can do that by unplugging the power cord or flipping the circuit breaker off for ten minutes.
If that does not correct your issue could you please provide me with your model number? Usually you can locate the serial tag (which lists your model number) inside your burner box or on the outside of the appliance base. With that information I can look further into your model. I look forward to assisting you. -Matt
