Why does it tell me error when in camera
SOURCE: Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
SOURCE: Camera won't work because the sd card is protected
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
SOURCE: no card displays on cannon 1000d camera
try with another sd card...if card is the problem replace it... if not try to repair it in authorised shop
