Phone was on and in standby mode. plugging in ac charger show a blue led momentarily then turns off.
Hi David
I think you should replace the lamp.
SOURCE: When Phone is put on
you can try a new battery if that does not work then you can take the phone to a mobile service center and ahve them diagnose it for you.
SOURCE: Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
