I have charged the battery, installed it, all the connections are good, but nothing will happen. The monitor will not even come on. What could it be?
All you need is a one trickle charger for the jet ski
battery.
Notice that there is a risk of damaging the battery if charged too much. So you just need to use an automatic charging station that can charge the battery to a full power and afterwards maintains it with a trickle charge.
If you plan to store a jet ski in a garage, you will need to
make sure it is dry and cool and with limited exposure to the sun. In general,
you need to do what you can to prevent rust and other grime that eventually may
cause mechanical issues.
Washing your jet ski is also needed after every use. You can
use your car wash products. I also suggest to read the user's manual, it may include
tips about maintaining your jet ski.
You can protect the engine with a special spray and water
repellant.
If you plan to store your jet ski for a while, it is preferred that you will disconnect the battery.
