Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
A
Anonymous Posted on Jul 06, 2014
How do you replace the isolator on a poulan pro 295 chain saw engine assembley?
2 Related Answers
Andrew White
  • 2239 Answers
  • Posted on Aug 23, 2011
SOURCE: Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Testimonial: "Thankyou very much !!"
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 06, 2012
SOURCE: need picture of fuel line connection on 42cc chain saw poulan
Please rate me
Bud
Replacing engine assembley isolator
Most brands of saws require partial disassembly of the saw to replace the isolators. Yours is probably no excepion. You should take numerous pics on your smart phone during disassembly to eliminate a lot of questions during reassembly. Make sure the correct length screws go back in their respective holes if there are multiple length.
Some older saws required near total disassembly to do it correctly.
Poulan pro 295
Not sure if this will work for you but I had a lawnmower with too much compression and my mechanic said i had put the wrong spark plug in which was too long and that caused too much pressure when trying to start I almost ruined the engine. I put the proper plug in and seems to work ok now.
Jan 06, 2018 • Garden
1helpful
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
1helpful
My Poulan Pro 295 chain saw starts fine, runs for a few minutes, then stops and will not start until completely cool. What could be my problem?
It sounds very much loke the ignition is playing up when hot, just as a little test when it starts to die slacken off the fuel filler cap does it pick up/re start? if yes it is a fuel tank breather issue, replace the breather.
Chain wont tighten up for Poulan 295 Pro chain saw
hi after awhile chains stretch, make sure they get oiled good. nut that holds bar must be lose, like a 1/2 turn then you can tighten screw . don't over tighten ether of these. it takes time to find your saws happy spot , so be patient and keep trying to tweak it tell ya find it..vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
I have a poulan pro 295.I cannot remove muffler to get to spark arrestor.I removed the 2 bolts and the muffler is loose but I can't get it off.
Hello Tom;
Look at the link "Engine Assembly" print. If your saw has multiple pieces like shown there is an additional internal screw. If not the only thing that comes to mind is remove the engine cover.
http://www.ordertree.com/modelinfo/PWE/PP295-Gas-Saw-Type-1/75.PP295-Gas-Saw-Type-1.1.59.1.html
There are other "PP295" saws listed here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
1helpful
Won't start
I have a poulan pro 295. Can't get it to fire. I've replaced the plug, and ignition coil. cleaned the entire chainsaw.
2helpful
I would like to go down A bar size our two on my poulan wildthing
I have a Poulan Pro 295 20".  When I bought it I also bought a 16"bar and chain and have been using those since.  They make the saw much easier to handle and are a better match to the available power. The key dimension is from the bar's mounting hole to its end.  At the store look at the normal replacement bar for your 18" saw, and pick out a 16" or even 14" bar with the same dimensions there.  This can be easily seen by laying one bar over the other.
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
