Tv was working fine last night but would not turn on this morning.
Was there a storm last last. Check the outlet by plugging in a lamp. First. If the outlet is working then try unplugging and plugging the cord to the back of the tv. If that does not work take an computer cord and use it.
Ifthat does not work you may have a problem with the power supply.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
