SOURCE: I didn't receive my instructional or users manuel for my Avanti AT380 Treadmill
GO THIS WEBSITE AND DOWNLOAD SIMILAR MODEL FROM AVANTI USER GUIDE:
http://www.manualsnguides.com/results.php#.TtV56Xpc71s
SINCERELY
http://www.manualsnguides.com/document.php?iddocument=Dwhbzqg9ue#.TtYPiXpc71s
User's GuideAVANTI
928S
Treadmill AND DOWNLOAD AND YOU MUST PAY FOR IT. YOU DO NOT HAVE ANOTHER SOLUTION. AVANTI IS DOES NOT ANY WEBSITE WITH CUSTOMER SERVICE. ONLY COMPANIES THAT SELL THE EQUIPMENT BUT WITHOUT TECHNICAL SUPPORT.
SINCERELY.
E.CUADRA
SOURCE: I need a user manual for Avanti AT380 Treadmill
www.iconservices.com
http://fitness.manulsonline.com
http://manualsfactory.com
since this place you must not find the exactly model, you must pay in some of them, and download something similar.
The problem is the factory is coming in australia, and there are not service in USA, and support. sincerely.
Do not waste your time searching in the WEB.!
E.CUADRA
MANAGUA NICARAGUA
Adjust the REED switch, see the diagram, clean it, tight the connector very well
2) replace the battery well, clean the contacts, retight the spring contacts with pliers very well.
and proof again. God bless you
SOURCE: suspect upper panel faultr,shows En9 in r/hand[speed]window at start up
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
