SOURCE: GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
SOURCE: I have a JGP336 Gas Cooktop. Two front burner do
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
SOURCE: 30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
you have moisture buildup in the switch,
you can blow dry it to dry it out.
or the contacts in the switch or switches are connected together.
or grease build up.
you have to open , take apart the cooktop to test to figure out which switches are bad., you can do this by unplugging each switch and testing it.
be causes.
once you figure out the bad switch or switches, you can order new parts, or drill open old switch to clean out and fix the switch for re use.
basically,
1, clean mositure
2. clean contact points
3. test to see if the switch works, by turning the wheel and check contact points.
4. crazy glue back.
5. put back and use.
