Picture has shifted; left side of screen reduced; right side has a piece of the left side picture
SOURCE: Picture is shifted 6 inches to the left
try moving the image with the adjustments.... wont work? change the 100uf 200volt filter just ahead of the flyback.
SOURCE: Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
SOURCE: vertical coloured lines on right hand of LCD Television
This can not be repair,the problems u discribing is the effect of the LCD screen itself dead using or some tthings or some hit hard at the LCD screen.Don't atemp to repair this tv,the LCD screen it dead.Yes,buy another tv.
SOURCE: MODEL: TH-50PZ85U I HAVE A VERTICAL
Hi
Thanks for using FixYa. As Plasma TV is a very hard working device so it produces lots of heat and around 75% issues in Plasmas are caused due to overheating. To start with you'll have to open the back of the unit and check for any bulged/bad capacitors on Y and Z-sus boards. As the sound is working fine so it seems that the power supply is fine, also check the control board for any bulged capacitors. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
