When I turn on the television, the screen stays black, and the Power (Blue) light, when the TV is on begins to blink. After a few seconds of blinking, it blinks rapidly, and then turns off, and the TV Off light turns on (RED.) Please help.
since it is unusual, have it checked by a competent technician. it may
only be a simple reset but nevertheless at least you wont be bothered
again by that problem
Mine never turned on but the blue power light would blink.I disconnected the upper y buffer and got light on the bottom half of screen and the blinking stopped.I have the upper board on order and I think this will fix my problem.There is a blink code somewhere,just count how many blinks.Start pulling connectors from power supply and when it quits blinking you've found the one,could also be the power supply with bad cap.
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen. Do you see standby red light blinking when TV shuts off after showing blue image for a while? If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution. Thanks.
Most likely your power supply is shot. That is the most common problem with tvs'. EIther power supply or convergance board. If tv won't stay on, then it's a bad power supply
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
