SOURCE: microwave wont heat up
Your signs point to a failed power tube. First though, does it defrost? If it does it is an electrical control problem. If it does not defrost, do the following.... With the power unpluged you may want to remove the outer cover, ( screws at back ), and locate a shiney metal box. That box is shielding for the power tube. Get the part # from the tube and replace. You could check price and availability at www.avnet.com . Make sure you replace all of the shielding exactly the way you found it. VERY VERY IMPORTANT!!!!!
