Not sure what year. Bought used no O&M Manual.
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
SOURCE: riding moweer wont charge the battery when mower
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
