Question about Craftsman Air Tools & Compressors
Speedaire 8z058 motor speed and horsepower - Craftsman Air Tools & Compressors
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
I have a 1/2 horsepower electric motor 230 volt 3 speed w/ capacitor HVAC fan assembly. how do I wire it to power by color coded wires?
Keeping in mind that some motors may be different
The most common wire colors on a 3 speed motor are as follows:
Red- Low speed
Blue- Medium speed
Black- High speed
Brown capacitor wires ( usually two of them connect to the two capacitor terminals doesn't matter which wire to which terminal)
White - Neutral wire on 115 volt systems or the other 115 volt side of a 230 volt system ( note on a 230 volt motor this wire may not be white). Remember this is the most common wiring but different motors may have different wiring.
Hope this helps.
Bob
Nov 30, 2014 | Heating & Cooling
Horsepower for bt5310
Dear SIR:
The elevation motor not depende from HP, you must RUN The software calibration for diagnose, and troubleshooting inmediately.
2) Adjust the speed sensor, clean it, tight the connector wires very well.
see the diagram attached. however the HP is about 1/4-1/2 depend of mark and type.
God bless you.
May 10, 2012 | Exercise & Fitness
Im just asking what size the motor for a 1994 ford probe???
A dual-overhead-cam 4-cylinder engine powered base Probes in 1993, developing 115 horsepower. The GT coupe held a 164-horsepower V6, also of dual-overhead-cam configuration. Both engines are Mazda designs. No more turbocharged engines were available. A 5-speed manual transmission was standard; 4-speed overdrive automatic optional. Except for a slight horsepower/torque boost in 1995 for the 4-cylinder engine, and a mild V6 torque increase the year before, powertrains saw no change in this period.
Hope this helps (remember to rate this answer).
Jan 12, 2011 | 1994 Ford Probe
Have a 12 lengths mechanical deep well, run by a 3HP US Motor. Wants to change the motor to a 1.5 HP to save on power. Tried this but the motor heats up. I presume I have to change the pulley size and or...
Thank you for posting your question here on Fixya.com.
No one can answer that for you without knowing information about the actual installation. In short, you can not lower the horsepower without dropping the load. If reducing the speed of the pump lowers the load enough you could then use a smaller drive motor but the pump will deliver less product as a result. Using a pump curve you should be able to calculate the reduced head from slowing the unit down and the horsepower required at that point of the pump curve. Size the motor accordingly. As a rule though, I doubt you could drop to half the horsepower and still operate the pump on its curve. You may need to put a 2 hp on it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 12, 2010 | Plumbing
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
All info(model# ect.) weathered off of unit. Need motor for blower. Looks like 4 ton. how many horse power?
1/4 horsepower, 1075 RPM, 3 speed motor with a 1/2" diameter shaft will do the trick. If you have gas heating, you will need the 115 volt motor., If you have electric heating, you will need the 208/230 volt motor.
Aug 01, 2009 | Heating & Cooling
Can't find parts for a Speedaire Model 5Z705
not sure of a relay you are referring to but check Grainger for speedaire which they are sold there.
Apr 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
115 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
