Blades wont activate
Check the timing belt, the belt just above the blade. The blades, if not turned 90 degrees to each other, will clash. Dumb design?; perhaps, but you need some way to overlap when you turn so tightly. I have an early 2000's vintage, but remove the shroud and check the belt. It may be broken. You can actually raise the deck to it's maximum, remove the spark plug for safety sake, and if each blade spins independently of each other and real easy [though one could be jammed somehow], you probably broke the belt. They were just a few bucks shy of $100 a few years ago; I bought two when my last one broke, and luckily I haven't needed the spare. When/if this is the problem, syncronize the blades so that one is 90 degrees to the other. The factory has marks stamped on the pulleys and housing somehow (I'm trying to remember exactly), but in the end lining up those marks achieves that orientation. Hope this helps, Chuck in Cleve Ohio area
