Hi, I have the same issue. I took off the plastic backside and managed a work around by removing the brown cable from the micro switch. It is now running again, but it won't get a signal when the water container is full ... so be aware when you start running it !
The fan is mounted on a very poor quality 3 angle mount. The weight of the motor distorts the mount over time so the the fan starts clipping other fittings when spinning. You can turn the mount around so the motor hangs upright again. The latest EBACs are of very poor quality...
Frost means one of two things, low refrigerant or low airflow across the coil. The unit probably has lost it's refrigerant charge ( or some of it's charge) even though it hasn't been used.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
