Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATF6000ES1, is displaying an "AD" code. The "AD" means that your appliance was in an automatic mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: washer won't drain completely. gives
YOU NEED TO CHECK FOR A BLOCKAGE IN THE PUMP OR THE PIPES LEADING TO THE PUMPS.ALSO CHECK IF THE PUMP PROPELLER IS SPINNING CORRECTLY AND IT HAS NOT BEEN DAMAGED.GOODLUCK.MOHAMED
SOURCE: Frigidaire Affinity dryer error code?
HELLO,
I HAVE A FRIGIDAIRE AFFINITY DRYER (AEQ6000CE32). WHENEVER I PUT THE CLOTHES IN IT JUST SPINS FOR 10 TO 15 MINUTES AND SHUTS OFF BEFORE THE ALLOTTED TIME. THERE IS NO HEAT IN THE DRYER. ANY SLOUTIONS?
