My wii console is on but shows nothing on my tv
SOURCE: disc stuck in wii console
If Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,that gives step by step information on Dis-Assembling with screenshots,even a novice can fix the disc eject problem with the help of this DIYGuide. It also gives information on fixing many Wii Related Problems,so its a kind of Wii Problems Reference Fix Guide.
SOURCE: Wii console unable to read Game cds
shake the unit with no cd in if it rattles then there is a cd stuck, you could try taking apart but its not easy you have to take off hidden screw caps & unclip panels using an old credit card so as not to dent the plastic, plus there is allways one or two screws hiding !
hope this helps !
SOURCE: wii console says wii connect 24 is off. how do I
To Access the WiiConnect24 setting:
SOURCE: wii console is not responding
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
