What are the steps in stopping one caller from calling into my cell phone; an iPhone 4?
You can call your service provider to block the number for you. Or you can directly block the number on your iPhone. Navigate to Settings>Phone>Call Blocking & Identifications and add the number to the block list. Here's a more detailed guide on that: How to Block Numbers on iPhone and Find Blocked Numbers on iPhone
It actually depends on the firmware from your provider but...
bring up the call log. Tap on the Info icon on the right hand side of the number you want to block. That should bring up the menu of options of what to do with the number; one of the options will be to "block this number"
SOURCE: I can`t block incoming sms`s. on my iphone 4. I
You can use the video or the manual on how to use the iBlacklist properly
iBlacklist Manual
Can't. Not an option on phones.
There's probably an app for that.
but not through the phone
SOURCE: my apple iphone cell phone are locked fore pass code
shut the phone off completely. then when you reboot try holding it's either your camera button then pressing and holding the pwr button as it boots until it takes you into download mode, in which you can do a master reset, but you'll lose everything on your phone... if that doesn't work try the same procedure but with pwr and vol down.
Need to block a specific phone number from calling or texting your iPhone? It could be telemarketers, spam text messages, or that crank that won't stop calling and messaging. Apple's iOS does not have a built-in feature to block a phone number, but there are other solutions.
1. Your carrier might be able to block individual numbers. AT&T has an optional feature called Smart Limits for Wireless that runs $4.99 per month. One of the many functions is the capability to block up to 30 numbers from calling or texting your iPhone.
Verizon Wireless offers Spam Control for no additional charge. This feature can be found under My Services when logged into your account, and blocks up to 5 numbers from calling or texting.
2. Owners of jailbroken iPhones can install apps from the Cydia Store that will block phone numbers.iBlacklist is fully compatible with all iOS devices, iOS 5 and older firmware. For a one-time cost of $12, iBlacklist adds a plethora of useful features to your iPhone including the ability to block calls and texts from individual numbers.
MobileLog is currently in development and will be offered for sale to jailbroken iPhone owners soon. The app will also provide many enhancements to the stock calling app as well as number blocking.
3. Make sure you've registered your iPhone number with the National Do Not Call Registry. This will not stop texts, but it will require most telemarketers to stop calling your line within 31 days. Complaints can also be filed using the same website, and phone number registrations with the service never expire.
4. Assign a silent ringtone to the numbers you don't want to answer. This stops calls from bothering you, but texts will still sound an alert.
5. Another calling only solution are services such as TrapCall, which has plans starting at $4.95 per month. No iPhone app installation is required, and once you're signed up TrapCall will unmask blocked caller IDs and blacklist unwanted callers. More expensive plans can be purchased that offer more in-depth functions.
