SBM 400H Hi yesterday i was using my homedics cushion . I had it set on shiatsu and i was controlling whereit went. I accidently pushed roller full...well it startd to go upwards and then started making clunking noises as if going off track. what should i do.....I dont want it to break with use just due to the cause of the clunkking noise. thanks
I was using Shiatsu Elite II Cushion, which is one of the most useful cushions for a massage. It is an efficient tool for relaxation, pain relief, and general comfort. For me, the Versatile massage modes, Soothing heat function, Adjustable roller width features were the reason to buy. Found this awesome tool from Massager House.
Link: https://massagerhouse.com
Mine did that and I tried turning it on and let it run through the cycles with no pressure on it. then it found its own track again and started working ok, but I am very careful with the controller now. Hope it helps.
SOURCE: Faulty Homedics SBM 300H Therapist Select Shiatsu.
My mom had the same problem so i unzipped it from the back, and once i started to take out the padding i saw that there was a wire unplugged so i plugged it back in and it worked!
