SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
SOURCE: epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
SOURCE: making an awful ratcheting noise during aggitation and spin cycles
rachet device under agitator is stripped.
SOURCE: Where is the reset button
there is no reset button, the reset for the system is to unplug it for at least 3 minutes from the wall socket, if it doesn't reset then there is a electrical failure of the central control circuit board.
SOURCE: Maytag model MTW5570TQ0 MAYTAG LEGACY SERIES STARTER
control panel removable to access timer
