Question about Samsung Televison & Video
How do i get my samsung c5500c to play my blu ray movies
It will play regular dvd movies, but not the blu ray ones yet it says it's a blu ray player.
    Genius:
  • Samsung Master
  • 1,316 Answers
Once you have found that Blu-ray player won't play Blu-ray disc, the first thing is to have a further check on your Blu-ray player because this is one of the main reasons that may result in failure. You can refer to this article: "Why Won't My Blu-ray Players Play Blu-ray Discs"
Posted on Nov 14, 2019
    New Friend:
  • 63 Answers
If none of the bluray movies playing then your BD optical has failed. Get a technician to check the unit phisically.
Posted on Jul 26, 2014
6ya staff
SOURCE:
ThaMp3Doctor
Corey Knoettgen
  • 8596 Answers
SOURCE: Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
Posted on Mar 07, 2008
Anonymous
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
Anonymous
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck Pruitt43@yahoo.com
Posted on Mar 31, 2009
Anonymous
SOURCE: my samsung bd-p1500 blu-ray player won't play
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Posted on May 10, 2010
Anonymous
SOURCE: CAN'T PLAY BLU-RAY DVD ON SAMSUNG DVD BLU RAY PLAYER
I have a Samsung BD-P1600 and was having similiar problem...played thru previews but would not play. Instead of just powering off/on... I pulled the plug on the ac cord out and left it out about 20 minutes and it now works !
Posted on May 17, 2010
Testimonial: "Thanks for responding. It's working!"
How to get software to see film from usb dvd c-370 samsung?
Sorry you cannot do anything about it. All it will do is play JPEG photo CD's and play MP3/WMA audio files other than the regular DVD disc.
It has no DIVX codec for playing downloaded movies. And one cannot load it.
Apr 01, 2011 | Samsung DVD-HD845 DVD Player
Samsung BD-C5500C with latest firmware will not play audio track out on fiber optic to yamaha receiver when playing Avatar BR. Works on Avatar's main menu screen but stops once the movie is started. Same...
I don't think this is a software update issue. Just as you said that the player has the latest firmware installed on it. Software update and latest firmware are the same thing.
I think this is a incompatibility issue. The disc is not 100% compatible with the player and that is why there is no audio via sound.
But one more thing you can try is to enter the player's menu, under settings, check audio settings. You can change the sound settings to mono, save settings and try again.
Good luck.
Feb 06, 2011 | Samsung BDC5500 Player
I. need my update de my blu ray modelbd c5500c ivancarlos55@hotmail.com
download the update from
http://www.blu-ray.com/firmware/firmware.php?id=24
burn it on a cd/dvd or if it can use USB stick then use the usb to update by playing it. Instructions come along with the download
Dec 24, 2010 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Trying to play Blu ray Prince of Persia... keeps sticking, then goes and the sound does not match the video... tried to then just play the regular dvd that came with the movie and dvd plaayer says "disc...
If you can, connect the unit to your network with a lan jack and check for updates. more than likely it's a software update. Run a disc cleaner thru it as well. hope this helps.
Sep 19, 2010 | Samsung BD-P1500 Blu-Ray Player
For avatar how fix samsung bd c5500c blu-ray
If this is a Blu Ray Disk then your unit needs a firmware upgrade to be able to play the new Blu ray format. Contact Samsung for the upgrade file, burn to a DVD and run. The update will allow your unit play the new BR Format.
Please rate my help ++++Thanks for uisng FIXYA
May 28, 2010 | Samsung Televison & Video
PS3 will play games but not movies
Well if the regular dvd's dont work.. I would recommend you to buy Blu-Ray movies instead.. PS3 is the best known blu-ray player. buy at least one blu-ray movie and try that.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
BD-p1500 no disc error plays blu ray movies fine but will not play regular DVDs. Comes up and says no disc
need to contact SAMSUNG CUST. SERVICE, they will inform you about a new firmware update need to be done to your unit , beware shipping will cost you around $40.00 , hope this information is helpful , AJ
Aug 08, 2009 | Samsung BD-P1200 Blu-Ray Disc Player
Samsung DVD (1500) Remote problem.
Try to reset the blu ray player's remote control.
Remove the batteries and hold down the POWER button on it for 30 seconds.
Then replace the batteries with fresh ones
Jul 03, 2009 | Samsung BD-P1500 Blu-Ray Player
Mar 07, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
