SOURCE: resetting code
Go to harborfreight.com; click on safes picture in the right column; then click on the safe that you have (#45891); then click on the instruction manual download icon at the bottom. This should solve all your problems.
SOURCE: i have a gordon digital electronic safe # P45891,
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
SOURCE: gordon electronic safe and can't open it
Wow , I have the same safe thats been locked for more than a year.
I locked the keys in the safe and forgot the code.
I took the thing out side and droped it on its corner and whala.
go figure it worked ,thank you to who ever was the first 1 to try that
cody in west palm beach,fl
SOURCE: I NEED TO RESET THE MASTER CODE ON THE GORDON
hi
menu > settings > security > change lock code > apply
master code in place of lock code and press ok > enter new code what
you want
