You have 2 Shift keys on the keyboard. If the other shift key is working
then the shift key that is not working is defective. You should
consider replacing the keyboard on your laptop. There is no setting on
Windows that can disable the shift key.
**Note : If both Shift
keys are not working, Try to check if
sticky keys feature on
windows is on. Sticky keys should be disabled. To disable sticky keys,
Click on start and Go into
control panel > Accessibility
Options,
and under keyboard there is
sticky keys. Remove the tick and
click
apply and OK.
**If
"Use Sticky Keys" is unchecked, that means sticky keys is
disabled.
