How to unblock youtubr
YouTube has been blocked in certain countries like Pakistan, China etc., The Block has been based on the region's IP range. So, If you enable an IP mask software on your system, you could browse YouTube. An IP mask software could mask your real IP address by a fake one. You can check the change in your IP address by visiting
IP-Details.com and have an IP lookup.
SOURCE: www.youtube.com
hi
here is the proxy for you (62.193.236.100) but this proxy works on yahoo page better
thanks
your friend.
SOURCE: How to unblock youtube in school
Hi : Here is are some solutions :
- VPN
A VPN lets you access Facebook from a normal internet
connection. It's a little bit of software that you install on your
computer and then run after you connect to the internet. It sends all
of your internet information through a different computer (located in
the US or UK for example)... Try www.witopia.net for more information!
- Proxy
A
less elegant option, but just as useful, is to use a web based proxy.
There are many of these available, one of the best is 'sneak me'
(www.sneakme.net). You input the web address that you want to access
and then click on 'OK' and you can go straight to the site you need.
- Business firewall bandwidth
Some
businesses buy bandwidth directly from Chinese telecommunications
companies, so multinationals for example can have full access to the
Internet without any interruption.
-Or you can use Google public DNS server ..
I hope this will solve your problem .
Please don't forget to rate !
SOURCE: how do i unblock youtube
Most likely it's been filtered the network admin via Firewall rules. Only option you might have is a logmein or teamviewer to connect to your home computer and play it that way.
www.logmein.com
www.teamviewer.com
Both place offer FREE PERSONAL remote access. It will need to be installed on both machines however.
Now if your the Network Admin. then you need to unblock the site, via a router, proxy server or dedicated firewall just depends on your infrastructure.
SOURCE: the youtube website was block .. how can i unblock
Are you using workplace/ college/ school computer network? If so, they have some sort of policies to apply for the internet use in their network. If you think you need to use youtube, just let administrator know, they will unlock for you.
There is proxy setting to block the website you want to access or it could be set up on privacy tab on your IE. But also have the way to get out of proxy setting, you can search on the web for that, such as: google bypass proxy..ect.But you are about to break the rules at your community and you do it with your own risk.
Hope this will help. Thanks for reading.
