SOURCE: JVC Error Code 02 Safeguard Mode
Brendon, The supply side tape guide can jump out of its track and cause the mechanism to lock up. The load motor is trying to load the tape but cannot, so the load motor driver "times out" and displays the E02 error you're seeing. If you can get to it, try reseating the guide into its track, be careful not to scratch or touch the drum assy located right near the guide track. Good Luck, I hope you can resolve the problem. Joe Weibel customelectronics.org
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
SOURCE: safeguard mode/remove battery & reattach
i have a handycam jvc gr-d53ag. now the device become error.
it says "in safeguad mode, eject and reinsert the tape.
i have done it still no progress. please help me with this problem.
i would be very appreciate it.
thx so much
